SOLID TO SURFACE
SOLID TO SURFACE
AlejandroAvila01
Message 1 of 14
SOLID TO SURFACE
AlejandroAvila01
I'm currently designing a chute for a bucket elevator, and normally I would do a surface skeleton and then project faces to make sheet metal pieces.
This chute is kind of hard to do it by extruded surfaces, so I tried to do it solid then convert to surface but couldn't find the way to.
Do you have a solution for this?
Replies (13)
Message 2 of 14
swalton
I'd try the Delete Face command.  Pick a face that you will leave open in the actual chute.
If you don't like that command, you could use the Thicken/Offset command and a 0.000 offset dimension.
Steve Walton
Inventor 2025
Vault Professional 2025
Message 3 of 14
AlejandroAvila01
That's not quite what i was looking for but it turned my piece into a surface, so it works.
Take your "accept solution" wise man.
Message 4 of 14
89198826955
you can build a surface using a 3d sketch
Message 5 of 14
89198826955
create working points at the top
create a closed loop using a 3d sketch
create a surface
stitching surfaces
get the result
Message 6 of 14
89198826955
Message 7 of 14
SBix26
You want to make that form out of sheet metal?  Which side(s) are open?  Can you attach a photo of something similar that already exists?  Can you attach your attempt here?  I suspect there is a relatively easy way to do what you're asking.
Sam B
Inventor Pro 2024 | Windows 10 Home 22H2
Message 8 of 14
AlejandroAvila01
Yes, I want to use it as a skeleton to make my sheet metal parts easier.
I don't think that really matters but attached is a picture showing how. As I replied before, deleting faces would make my piece a surface so that was really what I was looking for.
Attached 1. You'll see that there's a surface that I modeled so I can project edges and create sheet metal pieces.
Attached 2
att 1
att 2
Message 9 of 14
SBix26
I mean can you attach your Inventor file here so I don't have to make up my own dimensions?  What version of Inventor are you using?
How many individual parts will make up this piece?
It looks as if you have found a pretty good technique, so I will probably not add any valuable insights, but I still like to try my hand at interesting models!
Sam B
Message 10 of 14
AlejandroAvila01
It'll be somewhat difficult as there are several pieces in the assembly and I'm only allowed to attach maximum 3 files.
Currently using Inventor 2021. This would be the final result.
About 7-8, maybe we can optimize it to save some welding...
You can find a 3d view on this one... meanwhile I'll look for a way to share my assembly using this technique 😄
https://autode.sk/3WbBrlx
Message 11 of 14
SBix26
Zip parts and assembly together and attach-- zip is an acceptable format here.
Sam B
Message 12 of 14
JDMather
For sheetmetal I would do as Derived Components.
Attach your master file here for demonstration.
This will be easy.
Message 13 of 14
AlejandroAvila01
ATTACHED
I would love to see what do you mean by derived components, also a commnad i haven't used before.
Message 14 of 14
SBix26
Here is a different way to approach this.  Attached is a 2021 part file containing seven separate solid bodies modeled in sheet metal to make up your assembly.  I do not have time this evening to complete the job by using Make Components to derive the seven solids into seven parts and place them into an assembly.  Just note that when you do so, the parts (and therefore the assembly) will be connected to the master part file, and changes in the master file will change the parts and the assembly.  All the geometry is controlled from the one part file.
Sam B
