Solid line pattern for .dxf
Hi forum,
I am trying to create a .dxf file for CNC (FlowPath V6)
The profile lines are coming out as dotted lines using the default pattern of 28100.
What value can I put in my .ini file to specify a solid line?
Here is what my .ini currently looks like. When I attempt to use it, I get an error that the custom line type is invalid for IV_OUTER_PROFILE.
[FP EXPORT SELECT OPTIONS]
AUTOCAD VERSION=R12
USE CUSTOMIZE=No
CUSTOMIZE FILE=c:\program files\autodesk\inventor 2018\Design Data\DWG-DXF\FlatPattern.xml
[FLATPATTERN LAYER OPTIONS]
Tangent Lines=IV_TANGENT:Visibility=OFF;LinePattern=28100;LineWeight=0.0500;Color=0,0,0;
Bend Lines (Front)=IV_BEND:Visibility=OFF;LinePattern=28100;LineWeight=0.0500;Color=0,0,0;
Bend Lines (Back)=IV_BEND_DOWN:Visibility=OFF;LinePattern=28100;LineWeight=0.0500;Color=0,0,0;
Tool Centers (Front)=IV_TOOL_CENTER:Visibility=OFF;LinePattern=28100;LineWeight=0.0500;Color=0,0,0;
Tool Centers (Back)=IV_TOOL_CENTER_DOWN:Visibility=OFF;LinePattern=28100;LineWeight=0.0500;Color=0,0,0;
Arc Centers=IV_ARC_CENTERS:Visibility=OFF;LinePattern=28100;LineWeight=0.0500;Color=0,0,0;
Outer Profile=IV_OUTER_PROFILE:Visibility=ON;LinePattern=37633;LineWeight=0.0500;Color=0,0,0;
Inner Profile=IV_INTERIOR_PROFILES:Visibility=OFF;LinePattern=28100;LineWeight=0.0500;Color=0,0,0;
Feature Profile (Front)=IV_FEATURE_PROFILES:Visibility=OFF;LinePattern=28100;LineWeight=0.0500;Color=0,0,0;
Feature Profile (Back)=IV_FEATURE_PROFILES_DOWN:Visibility=OFF;LinePattern=28100;LineWeight=0.0500;Color=0,0,0;
Alternate Rep (Front)=IV_ALTREP_FRONT:Visibility=OFF;LinePattern=28100;LineWeight=0.0500;Color=0,0,0;
Alternate Rep (Back)=IV_ALTREP_BACK:Visibility=OFF;LinePattern=28100;LineWeight=0.0500;Color=0,0,0;
Unconsumed Sketches=IV_UNCONSUMED_SKETCHES:Visibility=OFF;LinePattern=0;LineWeight=-1.0000;Color=-255,-255,-255;
Tangent Roll Lines=IV_ROLL_TANGENT:Visibility=OFF;LinePattern=28100;LineWeight=0.0500;Color=0,0,0;
Roll Lines=IV_ROLL:Visibility=OFF;LinePattern=28100;LineWeight=0.0500;Color=0,0,0;
[FLATPATTERN GEOMETRY OPTIONS]
REBASE GEOMETRY=No
GROUP GEOMETRY=No
REPLACE SPLINE=Yes
SPLINE SIMPLIFICATION METHOD=Linear
CHORD_TOLERANCE=0.010 in
TRIM CENTERLINES=No
Elaine
johnsonshiue
Hi! LinePattern for Outer Profile is set to 37633. It should be 28100 (continuous line), the same as Inner Profile.
Many thanks!
Software Test Engineer
Hi Johnson,
My CNC guy who is using FlowPath V6. claims that the lines produced are not solid. That's why I tried a different value.
Are you saying that "theoretically" 28100 represents a solid line?
Elaine
johnsonshiue
Hi Elaine,
28100 is continuous line. The inner profile layer has it set correctly. Please change the outer profile layer setting.
Many thanks!
For this particular scenario (Flowpath V6) as the end user, I need to do the following to ensure that the lines in the .dxf files were solid:
1. Create a sheet metal part file.
2. Create a sketch.
3. Insert the .dxf file previously generated with "Copy as " as ACAD.
4. Remove multiple points and turn ellipses into arcs
5. Use Sketch Doctor until the sketch is OK.
6. Save the sketch.
7. Right-click the sketch and save as .dxf
This seems to do the trick. Thanks to a suggestion in another thread by kelly.young  Thanks Kelly!
Elaine
