Solid Hatch?
Solid Hatch?
Solid Hatch?
I am using Inventor 2016 and I am trying to make a drawing file of my model. I have taken a cross section of my model and there are certain components that  I would like to have as a solid hatch for clarity. I scrolled through the list of all of the hatches and I was amazed to find that there is no solid hatch.
I have read other forum posts that have talked about using the little pouring bucket button inside of a sketch, but this is not a sketch. If anybody could please let me know how to do this that would be great.
Sandro
-niels-
Does it really have to be solid or does it only need to appear solid?
If appearance is enough, just right click on the hatch, select "edit" and change the scale to something tiny.
If you want to fill the section, then you'll have to make a sketch and project the geometry you want to fill so you get a closed boundary.
Then you can use "Fill/Hatch Region" sketch tool to fill that boundary with a solid color.
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Thanks for the response niels!
I am still in such shock that there is no solid hatch...
I would definitely prefer that the region actually be solid but after reading your response I feel like making a extremely small scaled hatch might be the answer.
I am assuming that if I go the other route I might run into problems like if the part changes size the solid region may not change. Also I will have a file loaded with sketches which i would like to avoid...
sorry thinking out loud...
I will give it a try. Thanks again!
Sandro
JDMather
There is a solid hatch.
You have to hide the auto-hatch.
Hit S to go into Sketch within the view.
Project your boundary and now you have access to Solid Hatch.
Properly created boundary is associative - just like any other sketch in Inventor - it will update with changes (within logic).
Actually, I don't think you even have to hide the auto-hatch, just fill the boundary.
Color Fill Help
Thanks for your help guys, I have tried both ways and they both work perfectly fine.
With creating the solid hatch it looks like I am now creating a new sketch in the file which sucks, but then using a small scale to appear solid works but also sucks its not true solid.
Either way I have the result I need regardless of how I got there.
Thanks for the help guys!
Sandro
JDMather
It seems like it should be simple enough for Autodesk to allow change of an existing hatch to solid fill.
You might add this to the Idea Station.
