Inventor Forum
Solid Decal on Transparent Surface
6 REPLIES 6
mark.martinezECRPT
290 Views, 6 Replies
I am using Inventor 2023.  I am trying to put a decal on a transparent surface, but the decal comes out transparent as well instead of being solid.  Is there a way to make it solid like I did in Fusion 360?  This is a silk screen. See attachments.
6 REPLIES 6
I think your problem may be partly due to the difference in background settings and the active lighting style.
Kacper Suchomski
YouTube - Inventor tutorials | WWW | LinkedIn | Instagram
@mark.martinezECRPT
If you can share the Inventor part here, we can look at it and give you some direction on what might work for you.
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use  ACCEPT SOLUTION  to assist other users later.
Also be generous with Likes!  Thank you and enjoy!
Become an Autodesk Fusion Insider
Inventor/Beta Feedback Project
SBix26
in reply to: mark.martinezECRPT
Solid bodies are uniformly transparent/solid.  The solution is to apply the decal to a new solid body (thin extrusion the same size & shape) that has an opaque appearance.
Sam B
Inventor Pro 2023.2 | Windows 10 Home 21H2
Hi Mark,
Another low-tech way of strengthening the image is actually creating multiple Decals using the same sketch.
Many thanks!
Software Test Engineer
In my experience with Inventor the decals "inherit" a lot of the physical properties of the material it's applied on. For example - if you want a matte paper label on a shiny glass bottle you will need to create separate part OR a slightly elevated surface acting as a thin label (like paper).
I think this may be the issue here as well.  As it's just plain single-color text (or?) I'd suggest that you emboss it like 0.001 and add black color to it.
A similar issue with solution can be seen here:
https://forums.autodesk.com/t5/inventor-forum/decal-looking-pale/td-p/9077903
In the real world - is that Decal a separate part with adhesive to the body.
If yes, that is how I would model it in Inventor - as a separate part assembled to the transparent component.
