Announcements
Solid bodies how to flaten surface for print
lekoky
lekoky
Hi. I wonder if anyone can show me how to flatten the surface of this body so I can print it out as a paper template which I would fold manually to structure the desired model. Also is there a way how I can scale up and down the finished body for the preferred size in mm? Thank you
Replies (7)
lekoky
Here is attached the outcome I am hoping to get.
JDMather
You do not have any Bends or Rips in the part?
No thickness either?
gmwi
This is just a section of your Octaball. Once you rotate the solids you can then add bends to where you need/want them.
lekoky
Thank you. I will look at what you have done. Hopefully, I will be able to follow it from your file. I do not know much about Inventor. I only follow a youtube tutorial to create these shapes, a link below. But it does not give me an option afterwards to proceed with what is for me the final result - paper template.
lekoky
Thank you very much. Will open the file later and try to learn from what you have done.
lekoky
Is there a simple command where I can make this ball bigger or smaller before converting it to the flatten template? Thank you
johnsonshiue
Hi! You may use Direct Edit -> Bodies -> Scale. Or, derive it to another part and specify the scale on the derived body.
Many thanks!
Software Test Engineer
