software collaps
software collaps
juha_keskinen1
software collaps
juha_keskinen1
does enyone else have same broplem i update inventor to 2025 and its started collapsing with stupid things like updating view and stuff
SBix26
Do you mean that Inventor 2025 is crashing frequently?  Do you have update 2025.2.1 installed?  Do you get the Error Report dialog box when it crashes?  Can you give more details about what you are doing when it "collapses"?
Sam B
Inventor Pro 2025.2.1 | Windows 11 Home 24H2
johnsonshiue
Hi Juha,
Did you submit the crash report? If yes, please send me an email (johnson.shiue@autodesk.com). I would like to understand the crash better.
In the meantime, please make sure call critical Windows updates are installed and the graphics driver is updated. Go to the PC vendor site and install all critical updates applicable to your machine.
Lastly, go to Windows Display settings and select the recommended resolution and scale.
Right-click on Inventor desktop icon -> Properties -> Compatibility -> check "Run as Admin" -> click on Change High DPI settings -> check both boxes.
Many thanks!
Software Test Engineer
