Inventor Forum
Snap Fit - Plastic Part
2 REPLIES 2
Crstiano
354 Views, 2 Replies
Why SNAPFIT not get the angle defined (equal axis) ?
INV 2014 SP2 Up1
Cristiano Oliveira
ConsultCAD.com
Tags (2)
2 REPLIES 2
4donwan4
in reply to: Crstiano
I am not sure if we are looking an issue of the revolve feature and shell feature as I cannot explain how the snap fit is coming in at an angle. You cannot use the sketch option unless the angle is one of the axes in the origin folder. With your angle method all I can suggest is use the work point / work axis method in the attached part. I would also suggest making a initial revolution as I have done so you dont need the shell command. This seemed to correct it on my end.
Don
Crstiano
in reply to: 4donwan4
Hi Don,
only was for exemplify what I needed... (customer)
- For your information, GREAT, all right.
But, you agree with me what it's nothing intuitive having to create and workplanes axis, if you can inform the same directions without they.
Cristiano Oliveira
ConsultCAD.com
