Message 1 of 8
- Mute
- Permalink
- Report
Hi!
I'm trying to make a smooth connection between two tubes. The part is a modification of a frame generator part. The issue comes with the connection between two of the tubes. I would like to make the red area smoother, as if it were just one case holding the two tubes. I'm not able to make it, keeping the inside of the tube clean and smooth... Does anybody have a clue what could be the best solution?
PD: If you want me to share the file, please let me know how would be the best for you, it is an assembly, since it is a frame.
Thank you!
