I am trying to set up a number of parametric, adaptive assemblies that i can use as templates parts.
I want to be able to copy the design of the template assembly, go into my new assembly, edit the parameters E.G. Height, Width and Length. and be presented with my new assembly at the desired size.
I have got this far...
But where im stuck is; i have a maximum length i can make component parts (3m). Is there a way that i can tell this to inventor and it will know if a span is over 3m, to use 2x or 3x the same component but at a reduced length to fill the span?
Cheers,
