Dear All,
I am facing small porblem with inventor that i can,t access full toolbar.(PFA)
Even though my icon size is small.
Pls help.
Thanks in advance.
Datta Indalkar
up your screen resolution if possible, if not rotate your screen 90 degrees, hit ok or apply or whatever then rotate it back
I would not recommend to rotate screen. It is easier to press alt+space bar(first input after "application options is pressed). Then enter, then use arrow key up.
i ran into this problem on a couple of tablets with giro's, it was simple to rotate the tablet 90 degrees to see the click options. Used to be ctrl+alt+arow key to flip the screen but that doesnt seem to work with windows 8.1
