SM1 Threading 1.035"-40
Message 1 of 19
I want to design a part that will have SM1 internal threads which are used for mounting 1" optics. I could then use something like this SM1 retaining ring in my product.  POLARIS-SM1RR - Stainless Steel SM1 (1.035"-40) Threaded Retaining Ring
I can't select these options using thread or threaded hole (with HSM). Furthermore, I would need the machine shop/prototyper to be able to actually machine it. Does anyone know how to do this?
Replies (18)
Message 2 of 19
Curtis_W
Hi rpirlo,
I don't think that's a standard thread, so you're not likely to find much on it. This link seems to indicate that it's a proprietery thread:
http://www.practicalmachinist.com/vb/general/1-035-40-optical-thread-187167/
This link indicates that if you call Thorlabs they'll provide the specs:
https://www.engineersedge.com/wwwboard/posts/16167.html
I hope this helps.
Curtis
Message 3 of 19
originally,SM thread is used in sewing machine .Thorlab  apply  on optical thread now.0.jpg
SM05:nominal diameter is 0.5inch,and you can get  from the  figure : all thread  are 40 pitch per inch.
Message 4 of 19
Hello rpirlo,
Did you find a solution for this thread ?
here are the details of the thread, but i don't know how to draw this ?
Internal thread - UNS-2B
Min Major Diameter : 1.0350"
Min Pitch Diameter : 1.0188"
Max pitch diameter : 1.0234"
Min Minor Diameter : 1.008"
Max minor diameter : 1.014"
Any help welcome,
Have a nice day !
Message 5 of 19
JDMather
Attach your *.ipt attempt here.
Message 6 of 19
thank you for your answer. I'm sorry, but i don't know what does it mean  "Attach your *.ipt attempt here." ?
Have a nice day,
Jeremy
Message 7 of 19
JDMather
What CAD program are you using?
Autodesk Inventor Professional?
Message 8 of 19
Sorry, i'm on fusion 360.
Regards
Message 9 of 19
Hi there. I am really new to designing using CAD. I wanted to use the cad files provided by Thorlabs to visualize my setup using an optical breadboard and an appropriate bracket for the breadboard. Once I opened in the AutoCAD software I was really stuck regarding how to proceed from the 2D model provided. Could someone help me if you don't mind.
Thank You
Message 10 of 19
johnsonshiue
Hi! Are you using AutoCAD or Inventor? This is Inventor forum. If you need help on AutoCAD, please go to AutoCAD forum (https://forums.autodesk.com/t5/autocad-forum/bd-p/706).
Many thanks!
Software Test Engineer
Message 11 of 19
Hi. Did you figure out how to do it and if yes could you please share it? Thanks.
Message 12 of 19
JDMather
@Anonymous
Are you using Inventor or are you using Fusion 360?
If Inventor, what version of Inventor?
Can you Attach the *.ipt file (or *.f3d) of your attempt here?
Message 13 of 19
JDMather
Message 14 of 19
I'm using Fusion 360
Message 15 of 19
JDMather
Message 16 of 19
JDMather
Message 17 of 19
JDMather
You have posted in the Autodesk Inventor Professional forum.
The Fusion 360 forum  is over here...
https://forums.autodesk.com/t5/fusion-360-design-validate/bd-p/124
Message 18 of 19
Hi.
I think the info is for external thd
Do you know how to measure over wires.
Message 19 of 19
kun8316
these videos are really helpful. i now know how to make threads by inventor. can i know where i can find more about these videos? thanks.
