Slow startup when opening a part for the first time in Inventor
HaoNgo81
HaoNgo81
Community Visitor
Community Visitor
Hi everyone,
I’m experiencing an issue with Autodesk Inventor where it takes about 30 seconds to open a part (.ipt) the first time after launching Inventor. Normally, it only takes a few seconds. If I close the part and open it again, the speed is normal.
This happens every time I start Inventor for the first time after a restart or a longer pause.
Has anyone experienced a similar issue or have suggestions for a solution?
Thanks in advance! 😊
johnsonshiue
Hi! This could be related to a few areas. Make sure all critical Windows updates are installed and the graphics driver is updated. Right-click on Inventor desktop icon -> Properties -> Compatibility -> check "Run as admin" -> click "Change High DPI settings" -> check both boxes.
Go to Windows Display settings -> select the recommended resolution and scale.
Please help answer the following questions.
1) Check your project settings -> Folder Options -> Design Data. Is it in a local folder or a network shared drive folder?
2) Where are the Inventor files stored?
3) If network is unplugged, does it work faster?
4) If the anti-virus tool or network control tool is disabled, does it work faster?
Many thanks!
Software Test Engineer
