I need your help - Modeling a mouse
hoang_dang-van
hoang_dang-van
Hello, I'm modeling a mouse specifically the glorious model o Mouse.
im having trouble making the shape of the mouse.
I made some kind of surfaces and i want to cut through the mouse that is surface.
Does anyone know how i can do that?
Should i use loft, should i do it another way?
i'll leave a screenshot and the .ipt file of the mouse (im using the inventor 2024)
and also a picture of the mouse.
kacper.suchomski
Hi
You can use the Split tool (body mode).
If the first Extrude was in surface mode, a better command would be Trim Surface.
Kacper Suchomski
johnsonshiue
Hi! In terms of the cutting surface, I would use Revolve, instead of Extrude. It will create a more curvy face for a palm.
Many thanks!
Software Test Engineer
