Is it possible to add more paths to replace component?
ut2VF7RU
ut2VF7RU
I wanted to know if it is possible to add more pathfiles manually here ;
to make work faster. I am trying to replace a component.
Thank you
johnsonshiue
Hi! Library paths can be defined in the project settings. Go to Project and add more Library paths.
Many thanks!
Software Test Engineer
ut2VF7RU
Thank you it solved my problem , can I ask another question which is another topic ? I am using user parameters for my standard models , I want this properties like Length to be added to my model information in the properties. Is there any automatic way to do this? Like, when I check the model properties, I would like to see all the paramters I added for that model.
Thank you
dave.cutting
In the parameters window, mark the ones you want to include for export.
In the iProperties window, when you type in the field, you need to start with '=' and include any parameter you want inside <>.
You description would probably be something like =Block <length> x <width> x <height>
Inventor would then display Block 100 x 50 x 20 in the iProprties field.
Dave Cutting
