slot size change while scaling the model and they get loose
Message 1 of 10
I am newbie to Inventor, I want to create Tab and slot interlocking model, but when I scale the model, size of the slot get change and thickness of the material is constant so it get loose.
Kindly suggest, how to handle this.
Thanks in advance.
Replies (9)
Message 2 of 10
Daan_M
Did you fully constrain your scetches?
I think a picture of your scetches/part would help solve the question
Message 3 of 10
JDMather
Attach *.ipt file here.
Message 4 of 10
I have created test file having sheet thickness 2.5mm, if at any point of time if I want to scale the model then I want slot width to be remain constant (2.5mm),  I mean to say that while scaling the part how can we take care of the thickness issue so that it remain constant. Thanks.
Message 5 of 10
JDMather
How are you "scaling" the model?
Message 6 of 10
I am using derive option. Thanks.
Message 7 of 10
JDMather
That is probably not the best technique to use.
Can you create a completed assembly (the hard way) that illustrates your Design Intent.
Once your true Design Intent is understood - someone can demonstrate the most efficient technique to use in Inventor.
Message 8 of 10
johnsonshiue
Hi! When you use Derive Part, the scale applies to all bodies based at origin point. If you want to keep the slot size, you should use Direct Edit -> Move -> Faces. instead. Or, you can derive it and change the slot size using Direct Edit.
Many thanks!
Software Test Engineer
Message 9 of 10
OK, I will try the same. Thanks a lot.
Message 10 of 10
lena.talkhina
Hello @Anonymous  !
Great to see you here on Inventor Forum.
Did you find a solution?
If yes, please click on the "Accept as Solution" button as then also other community users can easily find and benefit from the information.
If not please don't hesitate to give an update here in your topic so all members know what ́s the progression on your question is and what might be helpful to achieve what you ́re looking for. 🙂
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям! | Do you find the posts helpful? "LIKE" these posts!
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
Лена Талхина/Lena Talkhina
Менеджер Сообщества - Русский/Community Manager - Russian
