Slot command issue Inventor 2027
I came across this issue, when using the slot command, if the slot centre to centre length is small the slot centre is offset from the sketch point. E.g. If the slot is 16.5mm wide and the OAL is 18.5mm the slot is off-centre, but is you change the OAL to 20mm the slot is back on sketch centre.
Also in an assembly when you try to constrain the slot radius you get an error message "Relationship was placed with respect to geometry that is no longer available"
