I am having a really hard time on creating a slice view in inventor.
I've followed all the steps, requirements are satisfied, yet when it comes to select a sketch, it does not select it, not even highlight or anything.
The sketch is associated with the view, i clicked in the right order.
Solved by jhackney1972. Go to Solution.
Can you attach a simple dataset that exhibits this behavior?
Or at least, an screen capture image showing expanded browser?
The slice command often gives users a difficult time since they think the slice will happen in the view which contains the slice sketch. You must have a once removed view to perform the slice on. Take a look at the attached Screencast and see if it answers your question.
John Hackney, Retired
Hi! Did you follow the below instruction?
If you still cannot figure out, please share an example so forum experts can comment further.
Many thanks!
