sketch shape cimcurference measurement problem
w-gg
w-gg
Hello.  So i need to measure circumference of a loop on sketch, you can see on screenshot, however when I try to use measure tool, i am only able to measure length of one part of it at a time and then have to manually add them all. Is there a way, to measure whole length at once?
Thank you in advance
jesseKH32J
Here check this out, while in the measuring tool you can press the green + next to whatever value you want from the measurement this will add up all items you press + on automatically for you. I was not able to find a way to measure the entire length with a single click unless you do a quick extrusion each time you want to measure in one click. Then you can click/measure the face and receive the same information.
w-gg
Thank you it works for me also I figured out, that i can extrude the sketch and then measure it with single click if it will be easier for me in future. Thank you for help
SBix26
When hovering over the loop, wait for Select Other to appear (or press Ctrl-A) and scroll down to Curve Loop:
Sam B
Inventor Pro 2023 | Windows 10 Home 21H2
w-gg
It works. Thank you
