Sketch Mirror Issues
baron_carleton
baron_carleton
Trying to mirror But get Failed to create mirror messages. Mirror about 45, vert and horizontal Construction lines. I can get the first mirror about the 45 no problem. But mirroring across the 90 lines fails.
Xun.Zhang
Hello @baron.carleton,
Just select all of geometries for mirror since some of geometries contains the references to the four construction lines, after that, it seems works well in my end.
Video (vert/hori): https://autode.sk/2yg82wI
Video (45 degree line): https://autode.sk/2EmQrIV
Hope it helps!
Xun
baron_carleton
First Mirror works fine as you state, it is as I then mirror again and again to get the final design attached. The secondary mirrors gives me so much trouble. It seems mirroring off of mirrored lines is the problem especially at the driven corners. I had to create a driven arc, not a mirror, at the final corner connections to make it work.
EDIT: IPT attached has the Bottom Left corner and center right arcs fail to mirror.
Xun.Zhang
In this case, it a bit complex to understand why it is failed with over constraints, but it is easy to fix with sketch block.
Create two more lines and make the 1/8 profile as a closed profile, mirror as what you did before and it just works perfectly.
https://autode.sk/2Elajwb
Please download the attachment for more references.
Hope it helps!
Xun
baron_carleton
That was the speed at which I was expecting this to take. I was trying to keep the interior of the sketch clean for export to DWG but this solution works. Thank you.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
