Hi All,
I conducted a test on assembly with Factor of safety to be yield strength and when the results were produced it says min factor of safety is 0.07 or 0.09 for different force. Is there a way you can override or set Factor of safety to be 4 or 5 because that's suppose to be normal range for most material. When do create study, there are only 2 options for safety factor , yield strength and UTS. So to see real effect of force and when it breaks, need to have correct safety factor.
With 0.07 its all blue which means no stress. Bottomline question is where can I set desired factor of safety ? if you indicate Factor of safety as Yield strength then whats 0.07 indicating ? I have slight idea but test results in FEA are confusing me.
Please help.
Thanks and Regards,
Yash
