Sketch Crooked
Sketch Crooked
Sketch Crooked
This is killing me- I'm trying to sketch on the right face (see picture) My part is centered on the origin planes properly. When I go to sketch on the right face the sketch is crooked because the origin of the new sketch is being defined by the arcs that I have on the edges of the part which doesn't properly reference my part and makes the new sketch crooked.
If I create a new plane offset from the origin plane, flush with the right face and then sketch on that plane the problem goes away, but I know there has to be a better way to do this. I don't want the sketch constrained to a plane, I want it to be constrained to the right face.
I cant constrain the part to the new sketch plane, it wont move.
Thanks in advance for any help.
Xun.Zhang
If you are creating a new sketch, after entering sketch environment, you can edit the coordinate system as below image shows.
If you've created a sketch already, you can exit the sketch environment and check the context menu to edit the sketch coordinate system.
Hope it helps!
Xun
Thanks for the fast reply,
When I try to edit the coordinate system it doesn't let me select an origin plane, or axis to align it with ?
Thanks again,
Ross
I'm sorry I figured it out. Thanks
