I am trying to check in an assembly with a frame generated part. The vault is telling me it cannot because there is already a file name "CW Skeleton.iam" The CW was added at the start to make it unique. How do I rename that file?
It does not show up in the model tree so I cannot seem to do anything. Can I just rename it in the folder? That seems wrong.
Thanks.
*** Please up-vote Spell Check, pull IV into the early 90's ***
Solved by Mark.Lancaster. Go to Solution.
@Anonymous
There's a few ways you can do to get past this..
As a Vault admin you could uncheck the options enforce unique file names. Get the files checked in and then enforce unique file names again. But I'm not a fan of doing that. But this would allow you to rename within Vault.
-OR-
In Vault can the original name skeleton file be renamed?
-OR-
You can use Win Exp to rename and reopen the model to resolve the issue.. But you could also use Inventor Design Assistant and rename it there.
Mark Lancaster
& Autodesk Services MarketPlace Provider
just one more option to add to Mark's comment.
you can also use Save and Replace.... from the Assemble tab, Productivity section. I have that on "SR" shortcut key to speed it up...
