Afternoon all,
I am trying to sort out a very annoying issue that keeps my work stuck without the possibility to continue, unless start over. But obviously I cannot do that after months of work.
Ok basically couple of days go I crated the route in the image attached (under ok), it didn't show any strange messages of errors.
But now every time I need to save and close or open it, there is a message about "Error occurred in setting pipe length. Route segment could be too short. Please check the segment min. length set in Styles." and then when I click "ok" the route become as shown in the second image (under wrong). So I am not able to have my project back as before, but only with this strange segment. I tried to change the length but I will change everything! It is a mess.
How does segment length adjustment work. (if this is the problem).
This is a serious problem for my work please help
Thank you all in advance
