I built a dynamic simulation model and animated it with the simulation player dialoguebox. After I saved the model and opened it on the next day, I was not able to find the Simulation Player DialogueBox. The simulation player menu appeared disabled . I did not see that the dialoguebox was hidden somewhere.
Can anyone help how to get the Simulation Player DialogueBox back?
Thank you very much
Simon Cai
Solved by JDMather. Go to Solution.
Can you Attach your assembly here?
Can you post screen shots of what you do see?
Shift Win S and Ctrl v in a Reply.
When click the "Simulation Player", the dialogue box is supposed to pop up. However, no matter how I clicked it and minimize everything on graphic areas, I did not see the dialogue box
Simulation Player | Inventor | Autodesk Knowledge Network
Thank you for quick reply.
What version of Inventor are you using? 2022? 2023?
If you reboot the computer and then create a New simple two component assembly does the issue persist?
Are you using (or were you using) two monitors?
