Inventor Forum
SImulation frictionless mid plane can't select
2 REPLIES 2
JohnBeach
570 Views, 2 Replies
JohnBeach
The attached file is a half model that I am analysing. I have split it in half and want to fix it at the bottom and apply a fricionless constraint to the exposed plane. For some reason Inventor simulation will let me select parts of the exposed plane; but not all. I have done this many times before so this is strange. I also tried extruding half of the plane away.
Has anyone any suggestions? I have 2014 SP1.
John
John
2 REPLIES 2
inchul.lee
in reply to: JohnBeach
inchul.lee
Autodesk Support
Autodesk Support
Hi John,
Try creating a work plane to split the face. Then you should be able to apply the frictionless constraint on the face.
Please have a look at the attached file and let me know if it's the result you want.
Thank you.
Inchul Lee
Hi John,
Thank you.
Inchul Lee
JohnBeach
in reply to: inchul.lee
JohnBeach
That worked well. Thank you.
It seems a shame that this extra step is necessary.
John
John
