Simulation CFD link in Inventor is missing
Message 1 of 15
i installed Simulation CFD2015 to my previously installed INV2014 but the Link to Simulation CFS is missing (where i can launch the active model and so on).
How can I add this?
Thanks in advance
Thorsten
Replies (14)
Message 2 of 15
DRoam
You might make sure the add-in is enabled. Go to the "Environments" tab, click the "Add-Ins" button (on the far right), click "CFD 2015" and make sure both checkboxes (Loaded/Unloaded and Load Automatically) are checked.
Then, restart Inventor as well as your PC if necessary.
Message 3 of 15
Thank you. I already took a look at that list but Sim CFD is not listed there. Is it possible to add it? Or have I to reinstall Sim CFD?
Message 4 of 15
I have this problem too. there is no cfd simulation on the add-ins. How do i add in the cfd simulation?
Message 5 of 15
blair
Make sure that you have a model opened first within Inventor, you should then see a "Simulation" tab on the Ribbon Menu.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Message 6 of 15
I have the model opened but the add-ins do not have the cfd simulation. The model I using is from the autodesk revit
Message 7 of 15
DRoam
Hi @Anonymous, sorry for not getting back to you, somehow this one slipped through the cracks.
Please try the following steps from the CFD support pages (here😞
  1. Navigate to the CFD installation directory, typically C:\Program Files\Autodesk\Simulation CFD <Year>
  2. Launch the application called SimCFDConfig.exe
  3. Select the CAD packages to install a plugin for
 After that, then go to your Inventor add-ins and see if the CFD add-in is available.
Message 8 of 15
Yup I did that already. But I'm unable to check the box for the CAD packages to install
Message 9 of 15
DRoam
Hm interesting. Can you post a screenshot of what you're seeing?
Also, this is something that @Jon.Wilde would be much more knowledgeable about, he's one of the CFD experts over on the CFD forums. If he doesn't respond here, you might consider posting this question there, since this is as likely to be a CFD issue as an Inventor one: CFD Forum.
Message 10 of 15
i using the revit 2017 for the model and cfd 2016. Here the problem i encounter. I'm unable to check the CAD systemsCapture1.PNG
Message 11 of 15
DRoam
Oh, your problem may be that you're using Revit 2017 but CFD 2016. CFD might not be able to recognize versions newer than itself.
Do you have Revit 2016 installed or just 2017?
Message 12 of 15
i installed only the revit 2017. Which revit year verison you will suggest to me to download so that it able to work on cfd 2016
Message 13 of 15
DRoam
Probably the same year as your CFD, 2016.
Message 14 of 15
Hey thank for the help. Revit 2015 able to work! Appreciate it
Message 15 of 15
DRoam
Great, glad it's working for you! Best of luck.
