Simplify Intersecting Assemblies with thousands on references
andrew_canfield
andrew_canfield
A rough description.
50 meter square site - four 10 thousand part assemblies in each corner & a fifth over the whole square.
the task is to create a reference model of the centre 5 meters square.
Some of the sub assemblies contain shrinkwraps - shrinkwrapping a shrinkwrap doesn't appear to work.
Creating an 'intersection' shrinkwrap  references 50 thousand parts & hangs the machine.
Exporting each assembly as a step file  - re- importing, select by plane & delete the unwanted is an option & will take a while.
The dream would be a 3D selection from Navisworks to use as a reference within an Inventor drawing - not currently possible?
Still thinking about possible alternatives.
Regards
Andrew
andrew_canfield
Things just became worse!
https://forums.autodesk.com/t5/inventor-ideas/import-step-files-as-assembly/idc-p/9084633#M36667
Might take a week to sort this model out.
andrew_canfield
After making a derive cut to remove unwanted parts this can be seen:
The left hand image is great but i would like to reduce the file size (there are more sub assemblies to add).
Hover the cursor over the workplane & a red ghost appears showing part of the original model - can't this be removed too?
export to STEP & reimport fix that issue - awkward workflow.
Regards
Andrew
johnsonshiue
Hi Andrew,
I think you pretty much exhausted the options. But, I am wondering if there is a better way to do this. Based on the image you attached to the original post, it looks like you would like to show the intersection envelope. Is it right? When the intersection is obtained, do you care about the participating assemblies around it?
Many thanks!
Software Test Engineer
