Simplify - How to keep individually defined envelopes
stuart_tauteF9ACM
stuart_tauteF9ACM
I'm having trouble keeping envelopes in my assemblies after simplification.
What I'd like to do is:
  1. Manually define envelopes around select objects in the assembly
  2. Run the simplification tool to remove unnecessary parts and features
  3. Output a Substitute that includes the manually define envelopes from step 1.
What happens is that the substitute is generated, but without those envelopes, and I can't figure out a way to add them in since the original part isn't present in the substitute file.
johnsonshiue
Hi Stuart,
What release of Inventor are you running?
Many thanks!
Software Test Engineer
stuart_tauteF9ACM
Hey Johnson,
Running 2024 Professional, Build 153, 64 bit.
johnsonshiue
Hi Stuart,
This is a limitation in the Simplify workflow (2023/2024), reported as INVGEN-67899. Currently we don't have a good solution. The fix is targeting the future release. In the meantime, you may want to use the Replace with Envelope option in the Simplify panel.
Many thanks!
