simple sheet metal tabs
bkeeneNEC7T
bkeeneNEC7T
Hello all,
Does anyone know a way to make a simple tab in sheet metal? When I do a bend it bends the entire edge. To do a partial, it seems I have to create a sketch first, create a floating face, then create the bend between the two edges to connect them.
I'm used to Creo, where we create a bend, then we can simply offset one or both ends right there in the bend tool. From what I can tell, when you create the bend it automatically creates the sketch which includes the dimensions from the end that are set to zero by default.  Am I overlooking something simple, or is this not possible in Inventor?
-niels-
Expand the flange dialog to get options for width extents:
(also, bend and flange are 2 different functions in Inventor. i assumed you were using flange)
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
bkeeneNEC7T
Thanks!
Always the tiniest details...
