Hi.
Is there a rule for close inventor with an iLogic. So far i have.
oTitle = Parameter("Formathjul - Masterfil.ipt.Tykkelse_skive") & "mm, " & Parameter("Formathjul - Masterfil.ipt.Antal_huller") & "stk, Ø" & Parameter("Formathjul - Masterfil.ipt.Øhul") & "mm" i = MessageBox.Show("The program has created the following files: " & oTitle & ".stl", "Want To close", MessageBoxButtons.YesNo, MessageBoxIcon.Question, MessageBoxDefaultButton.Button1) If i = vbYes Then (here i want to close inventor) End If
Solved by psaarloos. Go to Solution.
