Solved by Curtis_Waguespack. Go to Solution.
Right click on the pdf and select Send to Compressed (zipped) Folder.
Attach the resulting *.zip file here.
You can edit the cutting plane sketch and make an offset section as needed.
I see others experiencing the same problem lately.
Try a different browser (IE or Chrome?).
Hi sps_cad_guy,
You can try this:
It looks like you posted the PDF while I was typing so disregard the previous information.
This should get you the results you're asking for as I understand it. Keep in mind that your the added view label text will be static and will not update if your the Section B-B section line changes.
Also, someone is likely to point out that this way of calling out sections might not be aligned with certain ratified drawing standards, but if it is acceptable in your industry, and at your company, then you can make the call as to whether is is acceptable.
I hope this helps.
Curtis
