Hello guys, I have a movable part which I want to show its 'before' and 'after' position and was wondering on how to show it in drawing with a dotted outline. Sometimes I would need to show several positions in between as well. Here I have some examples of what I mean.
Solved by James_Willo. Go to Solution.
Solved by blandb. Go to Solution.
Solved by kacper.suchomski. Go to Solution.
I believe you would need an assembly with multiple parts in the same place to show travel like that.
As for making the part a dotted outline, you can change the properties of the individual part on the drawing like so
Hi
https://help.autodesk.com/view/INVNTOR/2025/ENU/?guid=GUID-00BDBDC4-CFA8-4BC2-936E-4028BB9FF0BF
Kacper Suchomski
Positional representation. then you can show the "moved" rep with an overlay
See attached video
Model States also support overlays if you prefer that method.
Overlay views are the preferred way of representing the moveable part. It should be straightforward to create.
