Show BOM with Delimeters on drawing
Phillip_Lucero
Phillip_Lucero
In the Bill of Materials I have it set to All Levels with Delimeters, but is there any way to make it carry over to drawing BOM?  It exports to excel better from the drawing BOM table.  Thank you, -Phillip
CGBenner
@Phillip_Lucero
Hi Phillip.  In your second image, the Item numbers are showing as Bold Blue, which indicates a Static value.  Usually this happens when the number has been manually changed, or the Item column has been renumbered based on some sort filter.  To remove the static text, simply pick the cell and delete.  The actual value should appear underneath it.
Chris Benner
Phillip_Lucero
Hello GCBenner,
As I've closed and re-opened the drawing they come and go and numbers weren't bold blue the last few times.  Problem solved for now.  Thank you.
