shock Dynamic Simulation Inventor Professional 2020
Message 1 of 15
Hi there,
How can I create a shock simulation of 2 bodies, for example to determine the speed, force required, position of the second body or the load on the component?
Can somebody help me to make the Dynamic Simulation ?
i attatched a .rar File + Foto with Module
Thank you all
Replies (14)
Message 2 of 15
JDMather
Double post.
https://forums.autodesk.com/t5/inventor-forum/impact-shock-simulation-inventor-professional/m-p/9321...
No Windows OS zip file Attached as specifically instructed.
Message 3 of 15
I attached it .
Message 4 of 15
JDMather
Message 5 of 15
Thank you very much for the Nice Videos, it was very Useful , can you send me Please your edit as Zip File
Thanks a lot
Message 6 of 15
JDMather
I will not be able to send the files till tomorrow.
I used the Input Grapher to define a time period to apply a Force.
Message 7 of 15
Thanks i will wait till Tomorow, yes i show the Video several Times ,but i stil a beginner in Simulation, your File will help me a lo to show excatly which dependences did you use and Joints ......etc. you can send me it as private Message also.
Best wishes
Message 8 of 15
JDMather
See Attached.
Edit the Force and click on Input Grapher.
Message 9 of 15
Thanks can i insert a Revolution Joint with Autocad Inventor Student Edition?
Message 10 of 15
JDMather
Yes, the student version is fully functional.
Message 11 of 15
Thanks for the Quick answer
Message 12 of 15
Hallo,
Warum ändern sich  die Geschwindigkeiten der Werkstücke nicht (cubic and cylinder Mass), wenn ich die Kraft ändere? Das Werkstück (Black  CUBIC Mass) sollen sich mit höheren Geschwindigkeiten bewegen mit Änderung der Kraft !! oder ?
Durch des Momentes musste die Würfel Masse nach dem Stoß höhere Geschwindigkeit haben als die Zylindrische Masse vor dem Stoß, wegen die unterschiedliche Längen des Hebelarmes von H-Profiles  !
Message 13 of 15
JDMather
Fügen Sie hier Ihre neue Baugruppe an.
Message 14 of 15
sorry, i wrote my Question of German
How can i change the Speed of the zylinder Mass and the Cubic Mass. The Cubic Mass should move with 3 x Speed of the zylinder Mass because the Efficiency of moment force.
We can use the same Module what i sent  before.
Message 15 of 15
i attached it again, if i change the value the Force the speed didnt change
