Shift select multiple objects
edhess
edhess
Is it possible to disable shift select in order to select multiple objects in a sketch? AutoCAD has the option to turn this off so that multiple objects can be selected one at a time (not with a window selection) without holding shift, but I can't seem to find it in Inventor anywhere.
Owner2229
Hi, I don't realy think there is such an option in Inventor.
Anyway, you can try to ask here instead, as Inventor Customization deals with coding (Add-Ins, Macros, Rules), not customizing settings:
Inventor General Discussion
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
Curtis_Waguespack
Hi edhess,
I can relate to you on this one, as I've been working in AutoCAD a bit more lately than I have in many years, and I keep holding Shift when I don't need to.
Unfortunately, I don't know of a way to change this in Inventor, but as you mentioned you can set AutoCAD to behave as Inventor does and maybe that will help a little, if you're bouncing back and forth.
And if you're having to do a great deal of this in Inventor you might be causing yourself too much work:
http://inventortrenches.blogspot.com/2011/03/inventor-101-simple-fully-constrained.html
I hope this helps.
Curtis
edhess
Thanks for the replies and links, they've answered my question.
