Hello to everyone ,
This is my first post ,i am in the begginer stage and i have some questions as my head is going to explode.
Im designing elevator car frames and the choise of using invertor has become a must still love autocad but anyway.
When im designing a car frame it is compined from many metal parts with different thickness ,it is important that all the parts come together by bolts and etc so im trying not to create one by one part.Im creating multisheetmetal parts but i cant make them with different thickness.
Second i realised that when i change the sheet metal defaults all the parts are changing so im changing the desired sheet metal default and by make part or make comp im creating the deired part with the desired thickness,but when im taking the deisired part and i place it in an another assembly it keeps the previous thickness from the start im doing something wrong with the work flow for sure.
Should be great if you could make different thickness multibody sheet metal parts in one ipt and you pick your each solid and change the thickness as you want and giving you each time the flat pattern.
Thanks again
