Sheet metal
Sheet metal
a20oligr
Observer Observer
Sheet metal
a20oligr
Observer
Observer
Hi! I have a problem when creating a face on the latest sketch. I want the new sketch to be "connected" to the other parts, with an 25 degree angle (as the other gables). I don't understand why it can't make a face, because I can't see any breaks(?) in the sketch.
JDMather
@a20oligr
What is the name of the Sketch?
I see lots of other errors in technique.
Try creating a Flat Pattern.
Your Sketch7 is not fully defined and Face2 does not make logical sense.
SBix26
Here's my attempt at starting from scratch.  I used Contour Flange twice and Face twice, no Flanges, no Folds.  I also modeled half of it and mirrored the solid body at the end to avoid extra work.  As someone here (@JDMather) used to post frequently: "Get lazy!".
I don't know how you plan to have this constructed, but the attached file (Inventor 2023 format) unfolds into one piece, though with a lot of material waste.
Sam B
Inventor Pro 2026 | Windows 11 Home 24H2
a20oligr
Observer
Observer
Thank you for your feedback, it was very helpful! 🙂
