Sheet Metal Unfold Rule Custom Equation Bending Condition 90 Deg < β <150 Deg
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am new to Inventor and will be thankful for the support and guidance from the experts.
I created an “L” of 50x50x20 with thickness of 1mm and bend radius of 2.5. I tried a custom formula and the flat pattern is matching the calculated length up to 90 deg and for any value above 90 Deg the flat pattern was not matching with the calculation. I can say up to 90 Deg - No problem.
As I could not find anything wrong with the formula, I tried with the constant value of Bend Compensation (v) and the flat pattern is not as per calculation. I tried with v = 0 , so that the flat pattern will be of 100mm for any angle. To my surprise up to 90 Deg the flat pattern is 100 but above 90 it is not 100 although v is 0. The observed values are given below. I feel with v=0 the flat pattern should be 100 for any bend angle and this is not the case.
With Bend Compensation (v) = 0
Angle Flat Pattern
30 100
45 100
60 100
90 100
100 98.658
110 97.003
120 94.876
130 91.988
135 90.101
The same problem was observed with Bend Deduction (δ) = 0.
With Bend Deduction (δ) = 0
Angle Flat Pattern
45 100
90 100
100 98.658
120 94.876
130 91.988
With Bend Compensation L=L1+L2+v and with Bend Deduction L=L1+L2-δ. Why the flat pattern is not 100 for angle above 90 deg and why the same flat pattern value for Bend Compensation (v) and Bend Deduction (δ). How to compensate this value. Please advise.
Krishnan
