I'm trying to get Inventor to unfold from A-Side, i don't want it to use inner radius an unfold from that.
I do need to be able to offset A-Side radius a given amount, fx. 1 mm
This is the length i need.
This is what i gives.
Thanks for your help in advance.
Hi
This topic has come up at least a few times over the last year.
The expansion is calculated for the neutral surface, not for the edges.
The position of the neutral surface defines the K-factor, which you can change in the default sheet metal settings.
Kacper Suchomski
Hi
Kacper Suchomski
@kacper.suchomski is right - it's all about the k-factor and how Inventor makes the allowance for the way sheet metal stretches in a press.
You are right in that i need it from the neutral surface, but it's not in the middle of the full thickness of the part.
This is for woodworking, so i need to make relief cuts allong the round corners.
I hope this clarifies my question.
Hi! Then you set K factor to either 0 or 1. Setting it to '0' will obey inner faces length, while 1 is for outer faces length.
Many thanks!
Many thanks!
I'm not sure which curve is the one you want unfolded to a known length. Is it the nearest edge, the black curve at 1mm or the yellow curve 2mm from the nearest face?
It's quite unusual to figure out k-factor this way - it is normally calculated as the ratio of the neutral axis to the material thickness and falls in the range 0 to 0.5. It is usually calculated by bending a sample of material in a press because different materials, knives and V-blocks all produce different results - but in your case it's wood!!
So you really want to 'cheat' Inventor's sheet metal knowledge and just get it to unfold the part to a specific length - with no stretch allowances. Work on the "ratio" part of the equation: Take the distance to your 'true length line' from the A Side and divide it by the overall "thickness" parameter. That's the "ratio" of thickness to neutral axis ('true length line' in your case) - and therefore your k-factor.
Your part looks to be about 12mm thick - so if you want the black line at 1mm from A-side to be the true unfolded length, your k-factor will be 1 divided by 12 = 0.0833. If it's the 2mm line offset from the A-side, then k-factor is 2/12 = 0.1667.
Sorry for the essay - I've never thought about k-factors that way. It could be very useful in something I'm working on... thank you 😉
Thank you for taking your time to answer!
and it's the black line that i want to hit on both inner and outer radius from the same side at the same time. as johnsonshiu points out the K-factor moves in different directions for inner and outer, there must be a way to calculate it from the selected A-Side faces.
I put the workings in my previous post:
Sorry again, but the question wasn't how to calculate it, but how to hit 1mm in from the selected A-Side with both an inner and an outer radius at the same time.
Thank you for being patient with me
K = offset from inner radius / thickness
Kacper Suchomski
Kacper Suchomski
Offset surface and use Unwrap tool.
Kacper Suchomski
Kacper Suchomski
Sorry maybe i was a bit to fast on the trigger, will check it out, thanks
Original Message:
Unfortunatly that isn't a possibility, since i need hole and exstusions from the unfoldet part/s
Original Message:
You won't get it. Sheet metal module is optimized for the design of sheet metal, not wood.
Create a flat wood model using classic modeling tools, then bend it in the appropriate places (also using classic tools).
Kacper Suchomski
Kacper Suchomski
That's not quite correct. I experimentally matched the K-FACTOR to the CEIBA plywood. The flat pattern is pretty accurate.
Alternatively, create a sheet pan without cutouts and add the cutouts in a flat pattern.
Or check out the Unbend tool.
Kacper Suchomski
Kacper Suchomski
The unfold tool seems interresting, will check it out a little more
@ChrGBJ - I don't think you are going to get this to work the way you want. I'd model it as two parts, each with the appropriate k-factor, then derive & combine them in a new part if you need a single part representation (just remember that it will not unfold correctly!).
Although Inventor lets you work with multibodies in sheet metal, it isn't capable of unfolding each bend using a different k-factor.
It is actually possible to unfold using multiple K-factors
You just have to draw the part correctly.
For each sheet metal function, you can define the unfold rule - And it doesn't have to follow the sheet metal rule.
I'll attach my model part for inspection
