I keep getting a sheet metal style error in the flat pattern of the piece I'm trying to fix. I don't know what it is but the warning box says "could not replace geometry with desired contour." This was created by a different draftsman who is no longer here so I can't ask him for help. It was created with Inventor 2021. I think it has something to do where the double flange meets the fold1. I attached the file for anyone to take a shot at it. any help would be appreciated. Thanks, Gary
I managed to resolve the problem by increasing the gap size by 0.1 of Flange6
Jelte de Jong
Blog: hjalte.nl - github.com
After deleting the Flat Pattern, and then trying to create it again in (2022) I get the following:
Hi! There are multiple issues with the part. First, the default Sheet Metal Rule is Johan Rule (and Unfold Rule = Johan Rule), while the active Unfold Rule is set to Vision BendTable1 (so are the Unfold Rule in each feature). The bend table seems wrong to me too. The bend allowance values are all zero. This does not make sense.
Some of the errors are related to Three-Bend Corner Relief. Probably the default type isn't doable at certain corners. Try using "No Replacement" as a test.
Many thanks!
Sorry but that did not help. There still is an error in the flat pattern. look at flat pattern in the history tree.
Changing the unfold rule to Bend Compensation took care of the flat pattern error, now the piece won't show up in Vision software for the brake press. Just one problem after another with this piece!! Thanks for your help anyway.
Hi! I am not sure what failure causes the flat pattern to fail in Vision software. It could be related to the 3-Bend Corner Relief. Go to Manage -> Styles and Standard Editor -> Sheet Metal Rule -> Johan Rule -> Corner -> 3-Bend Corner Relief -> Radius -> set it to 0.05. It should work better.
Many thanks!
