If I create a square to round, that would have 4 different sides. I can place rips exactly were I want the seams. Is there any way to make each side a solid body? I've been able to do this using the split tool. But it becomes very messy and difficult.
Solved by JDMather. Go to Solution.
if I make a square to round by thickening, a surface model.
how do I then add the chord lines to the flat pattern?
this is an example of what I need to send to my shop. I convert the chord lines to etch
for ease of fabrication.
