Hi all,
I have question. Is possible to easly fix this "error"?
I have surface, when I use thickness future this gonna happen.
Solved by johnsonshiue. Go to Solution.
well you´re right. But option is able to use just for one solid. I need two solids, upper part and bottom part.
Is change to create it with two solids?
In such a case - here is one of the solutions. I use Derive component route. You can have a flat pattern out of each part but the edges are not vertical. So, you will need more sophisticated laser cutting machine to produce the parts.
Cheers,
Igor.
Hi! Here is a slightly different solution using Unfold/Refold (see attached part). I did it within the same part. The idea is pretty simple. Unfold the body, thicken-cut the seam, and refold the body back. Repeat the process on the other body.
Many thanks!
Hello @Anonymous !
Great to see you here on Inventor Forum.
Did you find a solution?
If yes, please click on the "Accept as Solution" button as then also other community users can easily find and benefit from the information.
If not please don't hesitate to give an update here in your topic so all members know what ́s the progression on your question is and what might be helpful to achieve what you ́re looking for. 🙂
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям! | Do you find the posts helpful? "LIKE" these posts!
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
