Inventor Forum
Sheet Metal ,multiple bend tables for the same material ???
5 REPLIES 5
583 Views, 5 Replies
Hi all,
Is it possible to have multiple bend tables for the same material?
Hi all,
5 REPLIES 5
blandb
blandb
I guess you can create the desired bend tables you need, set a default bend table that you want for a default, and then choose which bend table you would like to use later if needed to change. Please see below.
Custom bend table 1 is chosen as the default bend table, but I can also choose to alter which bend table can be used with the defaults (Such as Bend table 2).  Hope this helps.
Autodesk Certified Professional
CadManagerMoffatNZ
CadManagerMoffatNZ
Hi Yashin
can you please clarify what you are trying to achieve.
Do you want to have a bend table with different bend radius (bend deductions) for the same material?
Did you find this reply helpful ? If so please use the Accept as Solution or LIKES button below.
Daren
Dell Precision 7720 + P3418HW
Windows 10
Product Design & Manufacturing Collection
Inventor 2021.0.1, Vault Professional 2021, Showcase 2017
Hi Yashin
Daren
Windows 10
in reply to: CadManagerMoffatNZ
Hi
thanks for the replys.
Yes thats exactly whatn I'am trying to do.
I really just want to know what inventor does , say if you create two bend tables for a material.
1)They both have the same thickness
2)They both have the same bend radii
3)But they have different correction values
Will inventor just use the first tables information?
Hi
johnsonshiue
johnsonshiue
Hi Yash,
Inventor Bend Table by itself is not aware of material. The bend allowance computed by the Bend Table is a function mainly of Thickness, Bend Radius, and Bend Angle. K-factor is used as a backup if there is a nonsensical value on the table. Sheet Metal Rule encompasses Material Style and a selected Unfold Rule, which points to a Bend Table or any other unfold means.
Many thanks!
Software Test Engineer
Hi Yash,
Many thanks!
in reply to: johnsonshiue
Thank you
Makes more sense , I understand how it works . Thought it was more complicated than it seemed .
Thank you
