- Mute
- Permalink
- Report
Hi, i have an issue with a simple model, has only 3 bends, with 1 restriction: model need to have different lengths, the smaller one on the top. As you can see below the model is a simple part, but inventor apparently can't create the flat parttern since after a bunch (seriously a lot, including unwrap) of tests of different dimensions and trying different features. I have a sketch below as a reference to my model that can have different dimensions, but a similar geometry. If anyone know anyway to get the flat pattern with the bend lines position, pretty sure that the geometry gods will recognize your wisdom. See below and attached files, currently using the bend part feature, but already used the fold and bend features in tests.
