Sheet metal - Flat pattern will not create
nathanRE6G9
nathanRE6G9
This part will not flat pattern for me. I want this to be cut from flat sheet before being bent to form the coil shape.
Any help is greatly appreciated!
kacper.suchomski
Hi
  1. Faces are not perpendicular to each other.
  2. The sheet thickness in the settings does not correspond to the thickness of the element (remember that the thickness is measured in the normal direction, so it will not be the thickness on the sketch - it is better to make a surface coil and thicken it).
  3. Use Unwrap tool.
Kacper Suchomski
blandb
We have had good luck with flights by not using coil, but using a 3D sketch Helical curve, lofting the inside and outside curves together and then thickening. Then we can flatten it.
See attached 2024
Autodesk Certified Professional
SBix26
Here's my contribution (2024 format), same technique as @blandb , but using your dimensions.
I see that you are using version 2024.1.  You need to apply the 2024.3 update plus the .3.1 update.  Autodesk fixes things and adds new functionality, but you can't take advantage of those unless you keep up to date.
Sam B
Inventor Pro 2025.1 | Windows 11 Home 23H2
