Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
This part will not flat pattern for me. I want this to be cut from flat sheet before being bent to form the coil shape.
Any help is greatly appreciated!
Hi
Kacper Suchomski
We have had good luck with flights by not using coil, but using a 3D sketch Helical curve, lofting the inside and outside curves together and then thickening. Then we can flatten it.
See attached 2024
Here's my contribution (2024 format), same technique as @blandb , but using your dimensions.
I see that you are using version 2024.1. You need to apply the 2024.3 update plus the .3.1 update. Autodesk fixes things and adds new functionality, but you can't take advantage of those unless you keep up to date.
Sam B
Inventor Pro 2025.1 | Windows 11 Home 23H2
