sheet metal flat pattern size is different when unfold
ankit_purao
Message 1 of 13
ankit_purao
why is the flat pattern showing me different dimension when unfold see the images below
Replies (12)
Message 2 of 13
n2vc4b
Hi Ankit !
That's right !
Pic 1:  You have measured two bend line.
Pic 2:  You have measured two out face .
Message 3 of 13
ankit_purao
yes
Message 4 of 13
ankit_purao
any solutions to keep the unfold line same as the folded measured part
Message 5 of 13
n2vc4b
Please attach file !
Tks !
Message 6 of 13
CadManagerMoffatNZ
It is possible to have the bend lines match the distance between faces but in a real manufacturing situation it is highly unlikely this will be the case.
To achieve what you are asking you can "manipulate" the sheet metal defaults and set a bend radius to give you the result you desire.
Did you find this reply helpful ? If so please use the Accept as Solution or LIKES button below.
Daren
Dell Precision 7720 + P3418HW
Windows 10
Product Design & Manufacturing Collection
Inventor 2021.0.1, Vault Professional 2021, Showcase 2017
Message 7 of 13
ankit_purao
i have a 1.5mm sheet so what should be the bend radius to match the above dimensions
Message 8 of 13
ankit_purao
find the file attached
Message 9 of 13
CadManagerMoffatNZ
Start around 2.42mm and fine tune from there
Daren
Windows 10
Message 10 of 13
ankit_purao
but its changing the layout of the folded part
Message 11 of 13
n2vc4b
Gob job !
Message 12 of 13
CadManagerMoffatNZ
Yes it will.
I have looked at your part and the feature will move on the part as they are not fully constrained sketches.
If you add dimensions / geometric constraints to the sketches the features will hold in position when you make changes to the styles.
By default i would suggest you add any missing dimensions to a hard edge ie outside (fixed geometry) not soft edges created from the bend plate extents.
Daren
Windows 10
Message 13 of 13
johnsonshiue
Hi! If I understood your request correctly, I believe you are asking something impossible here. The distance between two parallel bend lines cannot be the same as the folded parallel faces. It is because there is bend radius on both bends. The bend radius creates slight offset from the bend line.
It will only work if the bend radius is zero, where the bend zone collapses to a line. Inventor support zero bend radius input but on the 3D geometry, there is still tiny radius.
Many thanks!
Software Test Engineer
