Customising Tube & Pipe Style
Message 1 of 10
I want to customise the Tube & Pipe Style by using the existing fitting models (which I saved in Vault )from the supplier.
Currently only existing fitting style are able to get select.
Please suggest a solution
Replies (9)
Message 2 of 10
copy an existing style, edit it, save it...
Message 3 of 10
Thank you for the quick response
I had tried the same. But when we try to Browse for the fittings , its giving available fittings options only. There is no option to edit it. Please refer the attached image for your reference
Message 4 of 10
Mark.Lancaster
@Anonymous
It sounds like you want to edit the fittings, is that what you're asking?   Editing fittings come from the Content Center editor and not under editing a T&P style.  Are you looking to make your own fittings and/or edited the fittings that come with the Inventor installation?
Mark Lancaster
Message 5 of 10
Yes. I want to edit the fitting coming from Inventor installation.
How to do the editing the content library .Hope user level we will have rights for that.
Message 6 of 10
Mark.Lancaster
@Anonymous
Then you need to make your own custom Inventor content center library and copy over the provide family to your read/write library and then use the Content Center editor to make changes as needed.
Review this
https://www.synergis.com/2014/02/28/working-with-inventor-content-center-part-1-of-3/
https://www.synergis.com/2014/03/17/working-with-autodesk-inventor-content-center-part-2-of-3/
https://www.synergis.com/2014/03/28/working-with-autodesk-inventor-content-center-part-3-of-3/
and my Vault Bro @cbenner  also has a lot of great info on his blog site regarding this subject matter https://cadtipstricks.wordpress.com/category/inventor-tube-pipe/ and he is hosting a class at Autodesk University 2019 on publishing content for content center.
Mark Lancaster
Message 7 of 10
Thank you. We are close to the solution now
Currently I have only Read access. Which all permissions are needed to do this?
Message 8 of 10
Mark.Lancaster
@Anonymous
Read only permissions where?
Are you using Vault managed content center or not using Vault at all.
Mark Lancaster
Message 9 of 10
Yes.We are using Vault for content center management. I am not able to edit anything in that now
Message 10 of 10
Mark.Lancaster
@Anonymous
Sounds like you are not assigned the content center editor role in Vault.   Have you Vault admins add this role to your your Vault account.
Mark Lancaster
