Sheet metal flat pattern showing incorrect flat pattern length
lancerichmond
Message 1 of 38
lancerichmond
I know it's an old problem but, did anyone actually find a solution that doesn't involve playing around with code, re-writing bend tolerances or reinventing the K-Factor? I have a simple steel pipe in sheet metal that I have "ripped" to obtain the flat pattern. The correct length should be 314.16 mm when made flat, however, Inventor says it should be nearly 4 mm shorter! This is definitely incorrect......
Replies (37)
Message 21 of 38
lancerichmond
I only answered your question the way I did because I could not understand why you were asking a question to which you already had the answer. My .ipt has all the information you require. So if you are going to offer help in the manner a kindergarten teacher would teach children, rather leave the solutions to the adults instead of belittling me in your response....
Message 22 of 38
lancerichmond
But that's what I'm saying! 😂 Why do we have to play around with the K factor to get the correct flat pattern length? Surely Inventor should calculate that?
Message 23 of 38
SharkDesign
This IS the correct pattern length.
K factor of 1 is no deformation, you only get this in like paper or something.
If that's a 1mm steel tube, the flat pattern will be smaller because as you roll it, it will stretch and the circumference will increase.
  Inventor Certified Professional
Message 24 of 38
JDMather
Our flat sheet is what it is - it is NOT two different lengths (to achieve desired OD and ID).
It is one absolute length.
We can visually see an measure and calculate that the OD and ID are not equal.
We can measure (or calculate) the OD and ID and see that there is a difference of 6.28mm.
These numbers are all verifiable and logical.
So how did the flat sheet go from being one length to being two lengths (with a difference in length of 6.28mm) when bent?
A.  The material compresses on the inside of the bend and stretches on the outside of the bend.
A1. The neutral plane (neither stretching or compressing) is generally not midplane in the thickness, but usually closer the inside of the bend than to the outside of the bend.
A2. This means that the material generally stretches more than it compresses.
From the Machinery's Handbook - we see that this stretching/compression is dependent on
Thickness
Material Properties (for example Aluminum is different than Steel.  One Steel is different than another Steel...)
Bend Radius (by convention - the inside radius)
Bend Angle (by convention - the "outside" angle, the total angle of bending)
(Also Grain, but we will assume the material is isotropic).
So, we have to calculate the k-factor or the Bend Allowance based on all of these variables.
In addition to the variables listed above - the machine tooling has an effect.
We use k-factor when the tolerances are not particularly close - run a sample on the machine and set the appropriate k-factor.
When the tolerances are tight - then we run multiple tests and record a Bend Allowance Table that might need to be updated month-to-month as the machine tooling wears.
The starting material is shorter and stretched and compressed during bending to get the desired size.
As you say, this question has come up here many times - I have tried to lay out logically so that others searching in the future can work their way though the logic.
Message 25 of 38
JDMather
Keep in mind that in this discussion I am referring to Plastic Deformation rather than Elastic Deformation.
When we release the bending force - the intent is for the part to maintain finished form.
Sometimes we have to overbend the part to account for spring-back of the material.
One of my first CAD jobs back in the last century was to help in designing tooling for bending windshield channel frames for 747 to account for spring-back after bending (not strictly sheet metal in the Inventor sense of the term, but related).  This was done partially by trial-and-error successive approximation. So there is a bit of art to sheet metal design.
With elastic deformation the part would return to original flat form after bending force removed.
Message 26 of 38
johnsonshiue
Hi Lance,
As James and JD already mentioned, this is indeed behaving as it should per default K factor. It sounds like you may want to use a Bend Table. For example, the table may dictate the bend allowance to 0, when the bend angle is greater than 90 deg. Or, use a custom Bend equation to achieve the range-specific unfold behaviors.
Many thanks!
Software Test Engineer
Message 27 of 38
IgorMir
No, the flat pattern is (ODia.- Wall Thk.) x Pi.
That's for simple calculation on a floor. If you got access to the workshop - run a simple experiment yourself. Roll a piece of pipe and see the result.
Cheers,
Igor,
@lancerichmond wrote:
Pipe:
1. Outside diameter: Ø100 mm
2. Wall Thickness: 1 mm
3. Rip Gap: 0.0001 mm
4. Length/Circumference = Diameter x Pi = 100 x 3.142 = 314.16 mm
5. Inventor's Calculated Length = 310.641 mm
Web: www.meqc.com.au
Message 28 of 38
lancerichmond
Good Day,
So what you are ultimately saying is, Autodesk Inventor Sheet Metal is for working with bends ONLY and not rolling's?
Message 29 of 38
lancerichmond
Hi Igor,
Thanks for the input, however that still does not give me the result Inventor gives me for the length......
Message 30 of 38
IgorMir
Hi Lance,
As I have said - get a piece of, say, 6mm. Thk. aluminum (a piece of a flat bar is ideal) and run the test. Cut that bar to the length you think it should be to achieve the desired OD and roll it up. All doubt will leave you after that. Otherwise we will be discussing the topic till the cows come home.
Best Regards,
Igor.
Hi Igor,
Message 31 of 38
lancerichmond
Ha ha ha, yes, I agree, I think I can see some cows on the horizon already 🙂
I'll test this problem out practically and see what happens....
Message 32 of 38
IgorMir
And if you write back what you have learned from the test - it will be great!
Cheers,
Igor.
Message 33 of 38
lancerichmond
Hi Igor,
I found this on the Web,
It's just like you said! Problem is..... Autodesk Inventor doesn't quite agree, lol.
Message 34 of 38
IgorMir
I don't know - what's your beef with the Inventor. I am quite happy with the produced FP length.
Cheers,
Igor.
Hi Igor,
Message 35 of 38
BDCollett
Amusing discussion. This brings back memories of working in a sheet metal shop and the foreman looking at me with confusion when I mentioned k-factor. The idea the metal might stretch and change when folding often didn't matter to them because the tolerances were loose. That doesn't change the fact that the CAD software is still right, as it is right in this example.
Message 36 of 38
JDMather
1.  I found this on the Web,
2.  It's just like you said! Problem is..... Autodesk Inventor doesn't quite agree, lol.
1. Ah, the web, so it is written...
2. What material is this formula for?  All materials?  That would not agree with the Machinery's handbook, the "bible" of manufacturing information.
Using that formula (OD-Thickness) x PI =
and Inventor...
I've never measured a sheet metal flat out to 4 decimal places - but that looks like pretty close agreement to me...
The centerline is kFactor = 0.5
Message 38 of 38
Deansiddall
on round stuff set your k factor to .5
