Sheet Metal-Flat first then fold or Folded first then flatten
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
In the context of what I am doing, converting all 2d autocad drawings to 3d inventor.
Therefore the folded part has been cut and bent umpteen times.
Is it better to
1. draw the final shape and then flatten it or
2. draw each flange and then fold it.
I am thinking which would give the more accurate result, at the end of the day,
There is an existing autocad 2d drawing of the flat pattern, and an existing autocad 2d drawing
of the folded part. Obviously in autocad the link between the 2 is at the discretion ot the drafter
and his production team, whereas the link between the 2 in Inventor, is set by the software and
your settings.
In inventor the 2 would be linked by the sheet metal defaults, which I usually leave at the inner bend
radius the same as the sheet metal thickness.
I haven't had the experience of actually matching the bending of the model to what the brake press
(not CNC but the old manual type where you place the piece by hand and line up the bending line by eye) and brake press bending tool does (?the radius on the nose of the bending die??)
What are your experiences and advice out there
Mike Kovacik
Inventor Pro 2020 ; Vault Pro 2020
South Africa
